60
Getting error when i include XamOutlookBar control in my azure silverlight application...
System.InvalidOperationException
An unhandled exception was encountered while trying to render the current silverlight project on the design surface. To diagnose this failure, please try to run the project in a regular browser using the silverlight developer runtime.
   at Microsoft.Windows.Design.Platform.SilverlightViewProducer.OnUnhandledException(Object sender, ViewUnhandledExceptionEventArgs e)
   at Microsoft.Windows.Design.Platform.SilverlightViewProducer.OnViewUpdated()
   at Microsoft.Windows.Design.Platform.ViewProducerBase.<get_DesignModeValueProviderService>b__7(IInstanceBuilderContext invokingContext)
   at MS.Internal.Services.DesignModeValueProviderService.ValueTranslationServicePropertyInvalidated(Object sender, PropertyInvalidatedEventArgs e)
   at MS.Internal.Features.DesignModeValueProviderConnector.ValueTranslationServiceImpl.InvalidateProperty(ModelItem item, PropertyIdentifier property)
   at MS.Internal.FrameworkElementControl.FrameworkElementDesignTimePropertiesAdorner.SetDesignResizeMode(Boolean updateView)
   at MS.Internal.FrameworkElementControl.FrameworkElementDesignTimePropertiesAdorner..ctor(ModelItem item)
   at MS.Internal.FrameworkElementControl.FrameworkElementDesignTimePropertiesGrabHandleAdornerProvider.Activate(ModelItem item)
   at Microsoft.Windows.Design.Interaction.AdornerProvider.InvokeActivate(EditingContext context, ModelItem item)
   at MS.Internal.Features.AdornerProviderFeatureConnector.FeatureProvidersAdded(ModelItem item, IEnumerable`1 extensions)
   at Microsoft.Windows.Design.Policies.PolicyDrivenFeatureConnector`1.OnPolicyItemsChanged(Object sender, PolicyItemsChangedEventArgs e)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at Microsoft.Windows.Design.Policies.ItemPolicy.OnPolicyItemsChanged(PolicyItemsChangedEventArgs e)
   at MS.Internal.Policies.SoleSelectionPolicy.RaisePolicyItemsChanged(ModelItem oldSoleSelection, ModelItem newSoleSelection)
   at MS.Internal.Policies.SoleSelectionPolicy.OnSelectionChanged(Selection newSelection)
   at Microsoft.Windows.Design.ContextItemManager.SubscribeProxy`1.SubscribeContext(ContextItem item)
   at Microsoft.Windows.Design.SubscribeContextCallback.Invoke(ContextItem item)
   at Microsoft.Windows.Design.EditingContext.DefaultContextItemManager.OnItemChanged(ContextItem item)
   at Microsoft.Windows.Design.EditingContext.DefaultContextItemManager.SetValue(ContextItem value)
   at MS.Internal.Designer.VSDesigner.VSDesignerClientImpl.RestoreSelection(List`1 selectionOffsetsInXamlFile)
   at MS.Internal.Designer.VSDesignerClient.RestoreSelection(List`1 offsetsInXamlFile)
   at MS.Internal.Designer.DesignerPane.LoadDesignerView()
System.ArgumentException
Value does not fall within the expected range.
   at MS.Internal.XcpImports.MethodEx(IntPtr ptr, String name, CValue[] cvData)
   at MS.Internal.XcpImports.MethodEx(DependencyObject obj, String name)
   at MS.Internal.XcpImports.UIElement_UpdateLayout(UIElement element)
Do anyone got idea abt this error???
  • 138253
    Hello Rajesh,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post, but I wasn’t able to reproduce your behavior, so if this is still an issue for you, could you please send me an isolated sample project, where this behavior is reproduced, so I can investigate it further for you.
