I have encountered a strange situation In my webgrid. There are a few columns in my webgrid that stores only code. Each of them has a webcombo attached and those webcombo will help to display desciption according to the code.
The strange thing is some columns in the grid can display their description correctly, but others just display the code. When I click the cell, the selected item in the dropdown is correct. I have no idea what's going on.
After some investigation, the only difference between them is those can display correctly, use String as the code. Those that can't display the description, use integer as their code.
I have no idea what to do. Please help.
Adam
Hi Adam,
It has been a while since your post, however in case you still need assistance I would be glad to help.
As far as I can understand you are experiencing issues with the display value vs. text value of your WebCombos. I have researched this scenario but am unable to replicate the described behavior. Attached is my working sample.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
