460
onBlur for the WebCombo not found/working 8.1.20081.1000
I can't seem to find a way client side for the webcombo to trigger a funtion when the control loses focus usually this is the blur() or onblur() ... anyone have any ideas... it works for focus
function ddlFocus() { Log("WebCombo1:Focus"); }
var ddl = igcmbo_getComboById("WebCombo1");
ddl.focus = ddlFocus; //this works
  • 50
    I ran into this issue...here's what appears to be working for me....caveats: It's only tested for use with editable combos, and the code is only tested in IE. There's a crossbrowser attachEvent function at http://phrogz.net/JS/AttachEvent_js.txt that may be useful if you need to work in FF or downlevel browsers.
     The webcombo uses an input control internally....the basic idea is to get a reference to that input control and attach an event handler to it's onblur event.
    var ctl = igcmbo_getComboById(comboID);
    if (ctl && ctl.Editable)
    var box = ctl.getInputBox();
          box.attachEvent(
    "onblur",cboOnBlur);
    Next is the handling function....
    function cboOnBlur(oEvent)
       {//get the id of the event source
    var srcID = oEvent.srcElement.id;
    //since the event source is actually the input control, we need to tweak the id to get the reference to the webcombo
    var cbo = igcmbo_getComboById(srcID.substr(0,srcID.length - 6));
     If you were thinking of using
     cbo.attributes.add("onblur","myfunction(param,param2);")
    forget it, Infragistics ignores your request - they always write a call to their own onblur handler into the event handler.
    igcmbo_onblur(oEvent, webComboId)
