<ig:ultrawebmenu id="UltraWebMenu1" runat="server" Height="29px" TargetFrame="eContent"
Width="100%" Font-Size="12px" FocusOnHover="false"
BackColor="Control" Font-Bold="True" ForeColor="DarkBlue" BorderStyle="Solid" BorderColor="#4863A0"
BorderWidth="0px" TopItemSpacing="Compact">
<IslandStyle BackColor="White" BorderStyle="Solid" BorderWidth="1px" BorderColor="#4863A0" Font-Bold="true" ForeColor="#4863A0"
Cursor="Default" >
</IslandStyle>
<HoverItemStyle Cursor="Default" ForeColor="White" BorderWidth="1px" BorderColor="#4863A0" BorderStyle="Solid" BackColor="DarkBlue">
<Margin Bottom="0px" Left="0px" Top="0px" Right="0px"></Margin>
</HoverItemStyle>
<ItemStyle Cursor="Default" >
<Padding Left="10px"></Padding>
<Margin Bottom="1px" Left="1px" Top="1px" Right="1px"></Margin>
</ItemStyle>
<ParentItemStyle>
<Padding Left="2px" Right="2px" />
</ParentItemStyle>
<Items>
//Dynamic Bind Items at Code behind
</Items>
<DisabledStyle Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="Gray">
</DisabledStyle>
<SeparatorStyle CssClass="SeparatorClass" BorderStyle="Solid" BorderWidth="1px"
CustomRules="background-repeat:repeat-x; " />
<ExpandEffects ShadowColor="#C6DEFF" Type="NotSet"></ExpandEffects>
</ig:ultrawebmenu>
Ultrawebmenu as above layout, it works properly on IE8, Firefox 3.6 and Google Chrome,
however I found that same layout of ultrawebmenu as above no combability in Firefox 4.0 Beta, menu should show its subitems once mouse over parent items, but the ultrawebmenu look 'freeze'.
... but the WebMenu does NOT work in Chrome
So that has to be fixed also
I can confirm that the WebMenu in 10.3.20103.2120 works now on FireFox 4 and Chrome !Thank you.
Here's the full LeftMenu.ascx.cs user control which holds the Menu:
<%@ Control Language="C#" AutoEventWireup="true" CodeBehind="LeftMenu.ascx.cs" Inherits="Kaupthing.CustomerLendingLedger.Web.Controls.LeftMenu" %><%@ Register Assembly="Infragistics35.WebUI.UltraWebNavigator.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebNavigator" TagPrefix="ignav" %><div style="position: absolute; width: 100%;"> <table id="Table1" cellspacing="0" cellpadding="0" width="100%" border="0"> <tr> <td valign="top"> <ignav:UltraWebMenu ID="_ultraWebMenu1" runat="server" TargetFrame="" TargetUrl=""> <IslandStyle Cursor="Default" BackColor="LightGray" BorderWidth="1px" BorderStyle="Outset"> </IslandStyle> <HoverItemStyle Cursor="Default" BackColor="DarkBlue" ForeColor="White"> </HoverItemStyle> <Levels> <ignav:Level Index="0" /> <ignav:Level Index="1" /> </Levels> <Images> <SubMenuImage Url="ig_menuTri.gif"></SubMenuImage> </Images> <ItemStyle Cursor="Default"></ItemStyle> <DisabledStyle Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="Gray"> </DisabledStyle> <SeparatorStyle BackgroundImage="ig_menuSep.gif" CustomRules="background-repeat:repeat-x; " CssClass="SeparatorClass"></SeparatorStyle> <ExpandEffects ShadowColor="LightGray"></ExpandEffects> </ignav:UltraWebMenu> </td> </tr> </table></div>
Hi there !
I've downloaded version: 10.3.20103.2105 of the Infragistics35.WebUI.UltraWebNavigator.v10.3( Zip filename: NetAdvantage_ASPNET_20103.2105_SR ) and upgrated the solution ...
I'm targeting .NET Framework 3.5 in the project.
But the WebMenu still does NOT work in Firefox 4! I also tried Chrome, and it doesn't work there alsoIt works in IE 9.
Please reply to this ASAP ... why is the WebMenu not working ?I should note, that I'm using this workaround fix in my aspx page:https://ko.infragistics.com/community/forums/f/retired-products-and-controls/36753/ultrawebgrid-error-document-getboxobjectfor-is-not-a-function/215106#215106- Also tried removing this custom workaround, but the WebMenu still doesn't work ...I get all the top level items in my WebMenu, but they're NOT clickable and they won't expand the children when mouse-overed !?
Please reply ASAP Infragistics, this is messed up :-(
This is the complete registration of the DLL's in the web.config, as you can see they include the latest version of the binaries from you guys, v10.3.20103.2105--------------------------------------------------------------------------------------
<controls> <add tagPrefix="asp" namespace="System.Web.UI" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" /> <add tagPrefix="asp" namespace="System.Web.UI.WebControls" assembly="System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" /> <!--<add tagPrefix="igtbl" namespace="Infragistics.WebUI.UltraWebGrid" assembly="Infragistics35.WebUI.UltraWebGrid.v9.2"/>--> <add tagPrefix="igmisc" namespace="Infragistics.WebUI.Misc" assembly="Infragistics35.WebUI.Misc.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="igcmbo" namespace="Infragistics.WebUI.WebCombo" assembly="Infragistics35.WebUI.WebCombo.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="ignav" namespace="Infragistics.WebUI.UltraWebNavigator" assembly="Infragistics35.WebUI.UltraWebNavigator.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="igtbldocexp" namespace="Infragistics.WebUI.UltraWebGrid.DocumentExport" assembly="Infragistics35.WebUI.UltraWebGrid.DocumentExport.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="igtblexp" namespace="Infragistics.WebUI.UltraWebGrid.ExcelExport" assembly="Infragistics35.WebUI.UltraWebGrid.ExcelExport.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="igsch" namespace="Infragistics.WebUI.WebSchedule" assembly="Infragistics35.WebUI.WebDateChooser.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> <add tagPrefix="igtxt" namespace="Infragistics.WebUI.WebDataInput" assembly="Infragistics35.WebUI.WebDataInput.v10.3, Version=10.3.20103.2105, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" /> </controls>
i need this bugfix also!
Greetings Stephan
