In Visual Studio Data Sources.. I want to change the type of control to XamComboEditor.
When I use the dropdown on the field, Then go to "Customize..." XamComboEditor is not in the list.
My ultimate goal is to use the XamComboeditor to bind master-detail realationships.
If I use the standard Combobox and drag it as the master.. all works perfectly.
I cannot get the XamComboeditor to select the details.
Hoping that using the drag and drop feature from the Data Sources would bind it correctly.
Using Silverlight4, WCF RIA Services, Infragistics 2010.3
This functionality has been added in the latest service release.
Valerie
Currently this functionality is unavailable. I spoke with development on this issue and it will be implemented in the future. In the meantime, you can add the binding in the XAML.
