633
Node Edit Style
 I have a problem in Interent explorer. When the textbox for node editing appears, the text does not vertically fit in the text box, it is cut a little at the bottom. I am also using app styling.
I tried to set the NodeEditStyle font size property to get it to fit but that does not work. I also editted the css file used by the app syling theme, and set the font size properties in .igtr_BlueEdit but still no change.
I looked at the html that is generated and the input tag generated by infra has inline css defined in it which sets the height and font size of the input field. Any idea how i can set the values being set there.
 Ahmad
