235
XamGrid : Button in column header launch edit mode
I am using a XamGrid with a TemplateColumn. This column has an header template like this :
<ig:TemplateColumn.HeaderTemplate>
                                            <DataTemplate>
                                                <StackPanel Orientation="Horizontal">
                                                    <sdk:Label Content="Produit" Margin="0,0,5,0"/>
                                                    <Button x:Name="btnProduitsServices" Content="+" Margin="0,0,10,0" DataContext="{Binding GestionBDCViewModel, Source={StaticResource Locator}}" Click="btnProduitsServices_Click" IsEnabled="{Binding AccessibiliteBtnProduitsServices, Mode=OneWay}"/>
                                                </StackPanel>
                                            </DataTemplate>
                                        </ig:TemplateColumn.HeaderTemplate>
The button opens a ChildWindow. Then, when I click on the button, the XamGrid pass on Edit Mode. If I click a second time on the button, the ChildWindow is correctly opened.
Is there a way to open the ChildWindow, even if the XamGrid is not on Edit Mode (in my case on the first click)?
Thanks for your help,
Olivier
