Workbook newWorkBook = new Workbook();
worksheet1 = newWorkBook.Worksheets.Add("Sheet1");
worksheet1.Rows[1].Cells[1].Value = "testdssdg";
string testPath = "C://Test.xls";
newWorkBook.Save(testPath);
I am trying to write the Data to Excel int my WCF Layer. My data is huge so I dont want to return the huge data into client(ie Silverlight layer), Instead I want to write the data into excel file. But whenever I am trying to Save the Excel file it is throwing an exception
The type initializer for 'MS.Internal.JoltHelper' threw an exception.
Can you please let me know how to fix this issue.
I have attached my sample here. Can you please check and let me know whats the problem.
Hello Prakash,
I tested Exporting to Excel with domain data source, and I have not seen any issues with it. Your code seems to be fine. I am attaching a sample that demonstrates excel export functionality you may use to recreate the issue. Please feel free to modify the sample as you need, and if you reproduce the issue re-attach it here, and I will review it.
Thank you,Sam
