520
UltraWebGridExcelExporter output issue
I am exporting a hierarchical UltraWebDataGrid to xls using UltraWebGridExcelExporter v10.3.  When I call UltraWebGridExporter.Export, all works fine and the xls is created. However, it's contents contain only the following garbage and don't contain my hierarchical data.  The data in the dataset has already been bound via DataBind prior to calling Export.
        ReceiveStatement TRUE TRUE   ReceiveStatement TRUE   ReceiveStatement TRUE   ReceiveStatement TRUE TRUE   ReceiveStatement TRUE TRUE
Please help!
  • 520
    For the devoid of patience, here goes:
    1. The exporter control must be defined within the form, presumably because that is the only way it's state is preserved across postbacks
    2. Exporters don't like it if I handle  the grid's DataBound event. I still havent' figured out why.
    3. DataBind must be called immediately prior to the Export method call, *within* the export button handler.
    4. Init the grid's properties, setup handlers etc. in PreRender, not in Page load
