I have a xamGrid with editing disabled. One of the columns contain checkboxes and I want to change the value of the check box in the cell click event. Is it possible? If so, how?
Thanks.
The cell and the underlying data object should reflect the same value. The cell does not maintain the value it shows what is in the data object.
Thanks for replying. Yes, it does provide me the underlying data but how to change the value of a cell in that row?
In the cell click one of the arguments off the event args should be e.Cell. From the cell you can get to the row object and from there the .Data property which would be the object that the row represents
e.Cell.Row.Data.
You could change the value on your data object that way. As long as your object is implementing INotifyPropertyChanged then you should see the change reflected in the grid.
