I use this code to add a listbar
Dim ListBar As New Infragistics.WebUI.UltraWebListbar.UltraWebListbar
ListBar.Groups.Add("Pack")
ListBar.Groups.Add("Load")
_oCollection.Add(ListBar)
When this is added to the form I get javascript errors and the control doesn't work. Its not collapsable.
Error 'Control.Events' is null or not an object
Hello Chad,
Yes, indeed, I was able to reproduce the very same javascript error while trying to programmatically add a UltraWebListbar instance to a placeholder. After scratching my head and trying different things for a good 15 minutes, it turned out that UltraWebLisbar expects you to explicitly set and ID in order to register its client-side instance using javascript. Now that I think about it, this actually makes sense, however I believe we should add an exception that explicitly asks for an ID, since the javascript error is indeed not descriptive at all.
Here is my sample setup:
<asp:PlaceHolder ID="PlaceHolder1" runat="server"></asp:PlaceHolder> protected void Page_Load(object sender, EventArgs e) { UltraWebListbar ultraWebListBar1 = new UltraWebListbar();
ultraWebListBar1.ID = "ultraWebListBar1"; ultraWebListBar1.Groups.Add(new Group("First Group")); ultraWebListBar1.Groups.Add(new Group("Second Group")); ultraWebListBar1.Groups.Add(new Group("Third Group")); PlaceHolder1.Controls.Add(ultraWebListBar1); }
Hope this helps.
