115
WebAsyncRefreshPanel with ultrawebgrid
Hi All,
I am using WebAsyncRefreshPanel panel inside which I have added ultrawebgrid.
I have used refreshcontent event of WebAsyncRefreshPanel to bind ultraweb grid
When this asynchronous request goes to server I am getting small spnning image as a progress indication.
I used onrowupdate event of grid to update modified records into database.
When I click on grid cell and edit andI move away from that row the row Onrowupdate event is called. On server site data is getting saved.Till that time I am getting progress image.
During that process If I click on build grid or Export to excel I am getting two spning images as a progress indication.
I just wanted to set one progress image at a time and user wont be allowed to click on any button unless first request is not completed.
I wanted to set opacity to achieve this
Can any body please help me out to achieve this functionality.
Thanks in advance,
Mahesh Marathe
  • 49378
    Hi Mahesh,
    It has been a while since your post, however in case you are still having issues I would be glad to help.
    I was not able to reproduce the behavior you have described, however it should be possible to set the Enabled state of the WARP panel upon RefreshRequest and RefreshComplete client-side events. This should allow you to achieve the functionality that you are looking for.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
