405
Enforce Valid Date Range for my two WebDateChooser controls
I have two WebDataChooser controls:
1. Start Date
2. End Date
Now, I want some client side validation to ensure that my end date is not earlier than my start date. How do I do this? Is there any support for ASP.NET Validators (or at least free validators). Otherwise can you suggest any other solution?
  • 28407
    Hi, You can use a requiredfield validator and some client-side code.
    Here is a small crude page i put together to validate the start and end dates
    <%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
    <%@ Register Assembly="Infragistics2.WebUI.WebDateChooser.v7.2, Version=7.2.20072.61, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
        Namespace="Infragistics.WebUI.WebSchedule" TagPrefix="igsch" %>
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" >
    <head runat="server">
        <title>Untitled Page</title>
        <script id="igClientScript" type="text/javascript">
    var odate1 = null;
    var odate2 = null;
    function WebDateChooser1_ValueChanged(oDateChooser, newValue, oEvent){
     //Add code to handle your event here.
     debugger;
     var d1 = odate1.getValue();
     var d2 = odate2.getValue();
     if (d2 != null)
        if (d1 > d2)
          odate2.setValue(null);
          alert("bad date");
    function WebDateChooser2_ValueChanged(oDateChooser, newValue, oEvent){
     debugger;
     if (d2 < d1)
    // alert (d2)
     alert("bad date" + d2);
    function WebDateChooser1_InitializeDateChooser(oDateChooser){
     odate1 = oDateChooser;
    function WebDateChooser2_InitializeDateChooser(oDateChooser){
     odate2 = oDateChooser;
    </script>
    </head>
    <body>
        <form id="form1" runat="server">
        <div>
            <igsch:WebDateChooser ID="WebDateChooser1" runat="server">
                <ClientSideEvents ValueChanged="WebDateChooser1_ValueChanged" InitializeDateChooser="WebDateChooser1_InitializeDateChooser" />
            </igsch:WebDateChooser>
            <igsch:WebDateChooser ID="WebDateChooser2" runat="server">
                <ClientSideEvents ValueChanged="WebDateChooser2_ValueChanged" InitializeDateChooser="WebDateChooser2_InitializeDateChooser" />
            <asp:RequiredFieldValidator ID="RequiredFieldValidator1" runat="server" ControlToValidate="WebDateChooser1"
                ErrorMessage="RequiredFieldValidator start date needed"></asp:RequiredFieldValidator>
            <asp:RequiredFieldValidator ID="RequiredFieldValidator2" runat="server" ControlToValidate="WebDateChooser2"
                ErrorMessage="RequiredFieldValidator end date needed"></asp:RequiredFieldValidator>
            <asp:Button ID="Button1" runat="server" Text="Button" /></div>
        </form>
    </body>
    </html>
