Hello:
I have an ASP.NET application, form which uses the WebDataGrid (Infragistics35 - v10.3)
I want to use the styles available at http://localhost/ig_common/20103CLR35/Styles
Please could you provide steps for implementing this in my project
The below syntax does not seem to be working, something is missing in the path.
AutoGenerateColumns="False"
AutoCRUD="true" Height="470px" Width="800px" DefaultColumnWidth="100px"
StyleSetPath="/ig_common/20103CLR35/Styles"
StyleSetName="Office2007Blue">
Would it be possible to add this to my config ?
I see that ig_common is added as a Virtual Directory on IIS, so how do we use this on a Production server.
My Styles works perfect if I add the folder to the project. But would it be possible to user the Styles available on IIS.
Thank you
Sushma
Hello Sushma,
Let me know if your new approach is working or you need some other solution.
Thank you for your reply. I was still kind of unsuccessful with this. I am using this approach for now,
<infragistics.web enableAppStyling="true" styleSetName="Office2007Silver" styleSetPath="~/Styles" />
Thank you,
Let me know if you have any other questions.
If you have copied your Styles within a virtual directory, which can be listed when you type something like this: http://localhost/ig_common/ you can add link to this Styles in your “web.config” file like this:
<configSections>
<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
</configSections>
<infragistics.web styleSetName="Default" styleSetPath="http://localhost/ig_common/"/>
That code has to be placed inside the <configuration> tag, but before <system.web> tag.
Let me know if you have any further questions.
