305
Problem displaying BoxChart using XamWebChart v10.3
I am trying to develop a BoxChart based on some measure values. But getting some message in chart area "XamWebChart Warning: The box chart needs Min, Max, Q1, Q2 and Q3 values. The values have to be set for every data point using Chartparameters collection.".
I have already supplied the required values. But still getting the message.
Can you please provide me with some solution.
Following is the code i am using to generate DataPoints along with it's ChartParameters:
// to use the zoombar control with chart set the following properties on the axis
if (this
.PivotGrid.DataSource.Result.RowAxis.Tuples.Count > 5)
theChart.Axes.Clear();
Axis primXAxis = new Axis
primXAxis.AxisType =
AxisType
.PrimaryX;
primXAxis.ScrollEnabled =
true
primXAxis.ScrollPosition = 0.21;
primXAxis.ScrollScale = 0.17;
theChart.Axes.Add(primXAxis);
theChart.ZoomRectangle.Enabled =
true
Series series = new Series
series.ChartType =
ChartType
.Box;
for (int
i = 0; i < lstOCol.Count; i++)
var MinValue = ((ObservableCollection<DataPoint
>)lstOCol[i]).Min(p => p.Value);
var MaxValue = ((ObservableCollection<DataPoint
>)lstOCol[i]).Max(p => p.Value);
ChartParameter chartParams = new ChartParameter
DataPoint dd = new DataPoint
foreach (var x in ((ObservableCollection<DataPoint
>)lstOCol[i]))
chartParams.Type = Infragistics.Silverlight.Chart.
ChartParameterType
.Min;
chartParams.Value = MinValue;
dd.ChartParameters.Add(chartParams);
ChartParameterType
.Max;
chartParams.Value = MaxValue;
ChartParameterType
.Q1;
chartParams.Value = x.Value;
ChartParameterType
.Q2;
ChartParameterType
.Q3;
series.DataPoints.Add(dd);
series.Label =
this
.PivotGrid.DataSource.Result.ColumnAxis.Tuples[i].Members[0].ToString();
Following is the message i am getting:
Thanks for the help in advance.
Thanks & Regards,
Sachin Pandya.
  • 335
    Have you added the new series you created to your chart - theChart.Series.Add(series); ? I could not find such code in the snipper you posted.
    Also try setting chartParams = new ChartParameter (); after each time you added the parameter to the DataPoint ChartParameters collection.
    foreach (var x in ((ObservableCollection<DataPoint>)lstOCol[i]))
    chartParams.Type = Infragistics.Silverlight.Chart.ChartParameterType.Min;
    chartParams.Type = Infragistics.Silverlight.Chart.ChartParameterType.Max;
    chartParams.Type = Infragistics.Silverlight.Chart.ChartParameterType.Q1;
    chartParams.Type = Infragistics.Silverlight.Chart.ChartParameterType.Q2;
    chartParams.Type = Infragistics.Silverlight.Chart.ChartParameterType.Q3;
    series.Label = this.PivotGrid.DataSource.Result.ColumnAxis.Tuples[i].Members[0].ToString();
    Hope this helps,
    Boyan
