Hello
I have create property
public Boolean IsComboEnabled { get { Boolean field1= true; if (null!=this.field2) { field1= false; } return field1; } }
In the xaml I have <ig:CheckBoxColumn x:Name="xxxCheckbox" HeaderText="xxx" Key="IsComboEnabled"></ig:CheckBoxColumn>
I want the combo in Templatecolumn to change based on whether the checkbox is slected or deselected
I have set the value of combo in template column as
IsEnabled="{Binding IsComboEnabled,Mode=TwoWay}"
But it does only work for the first time page is loaded not when the user is on page and selects or deselects the combo
Thanks for the direction Darrell
I am using Converter for the enable disable property of the other control
Thanks for the sample Darell
The only difference i have is when the checkbox is selected the textbox should be disabled
I am not sure how to pass the opposite value of checkbox to the textbox
I don't think that code snippet is going to do what you want it to do
The IsComboEnabled property is is read only. Which fine, but then you really don't need a checkbox column as it's not going to change it's value if you check it.
And you are setting a TwoWay binding between the IsComboEnabled property and the combo IsEnabled. Are you planning on changing the combo's property and having the object's IsComboEnabled changing?
I am attaching a sample showing a possible partial solution.
