70
Selected Item not getting reflected in XamComboeditor Silverlight
I am using silverlight XamComoEditor. In my scenario I need to bind string collection to the comboeditor. I have enabled editing. I got an exception when I entered a new item since the new String object was not getting created. I found a workaround for that.
My problem is when I select a value from the dropdown list, nothing gets selected i.e the selection is not retained. When I set the 'IsEditable' property to false, the item gets selected. But when I set it to True, the selection stops working. I guess I must be missing somthing.
Can anyone help me to make this work...
View is Like this:
Grid x:Name="LayoutRoot" Background="White"><ig:XamComboEditor Height="30" Width="100" BorderBrush="Orange" ItemsSource="{Binding Path=StringCollection,Mode=TwoWay}" IsEditable="True" CustomValueEnteredAction="Add" DataObjectRequested="XamComboEditor_DataObjectRequested" VerticalAlignment="Top" Margin="0,70,0,0" /></Grid>
 Code Behind is like this:
public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            ViewModel vm = new ViewModel();
            this.DataContext = vm;
        private void XamComboEditor_DataObjectRequested(object sender, Infragistics.HandleableObjectGenerationEventArgs e)
            List<UIElement> items = new List<UIElement>();
            GetChildren(((XamComboEditor)sender), typeof(TextBox), ref items);
            TextBox txtbox = (TextBox)items[0];
            String str = new String(txtbox.Text.ToCharArray());
            e.NewObject = str;
            e.Handled = true;
        private void GetChildren(UIElement parent, Type targetType, ref List<UIElement> children)
            int count = VisualTreeHelper.GetChildrenCount(parent);
            if (count > 0)
                for (int i = 0; i < count; i++)
                    UIElement child = (UIElement)VisualTreeHelper.GetChild(parent, i);
                    if (child.GetType() == targetType)
                        children.Add(child);
                        break;
                    GetChildren(child, targetType, ref children);
ViewModel is like this:
public class ViewModel
        private ObservableCollection<string> stringCollection = new ObservableCollection<string>();
        public ObservableCollection<string> StringCollection
            get { return stringCollection; }
            set { stringCollection = value; }
        public ViewModel()
            stringCollection.Add("test1");
            stringCollection.Add("test2");
            stringCollection.Add("test3");
            stringCollection.Add("test4");
            stringCollection.Add("test6");
Shruti
