I have XamGrid 10.3 and using ConditionalFormatting. I have the style setter to Set the BackgroundProperty and AltBackgroundProperty to Red. However, when I see the grid on Alternating rows it is applying an opacity. I have attached a screen shot. You'll see on alternating rows, either the Red or Green colors are not what I have specified. What am I missing?
I was able to solve my problem using the CellControlAttached event. The trick was the custom style for red or green. Anyway, thanks.
I am using a custom Control Template. So, is there an example of doing custom conditional formatting through a Converter? I cannot remove my custom template. My data already has information on what color it should be, but it is being held in another property. I would like the cell's background to be based off a converter. Below is a sample of my class and data. Is this possible to do?
class Data{ public Decimal UpTarget {get;set;} public String UpTargetColor {get;set;}}
sample data...
50 NA
100 Green
150 Red
I'm not really sure whats going on. We don't apply an opacity to the element int he ControLTemplate thats used to display the Alternate Background.
Do you have a custom ControlTemplate applied via a CellStyle?
Also, what kind of CF rules are you using?
-SteveZ
