I have a three level menu. When the third level is displayed it pushes off the end of the page. Therefore it goes back to the left. When this happens it is going behind another level. How do I fix this? If it doesn't push off the end of the page everything is fine, each level is displayed to the right of the last.
I am using version:
10.3.20103.2120
I have a similar problem in Version 11.2. Has there been a work around or has this issue ever been resolved?
i placed the files you suggested with the support ticket. let me know if there is anything else you need from me.
Hello Julie,
Thank you for the update.
I recommend you attaching the screenshot and the markup of the page in a zipped format.
I created a new support ticket on your behalf : CAS-64023-PPTVXD
You may monitor it through our website.
1) Log in with your credentials:
http://ko.infragistics.com/Default.aspx
2) Navigate to MyIG -> My Support Activity -> Select Active tab
3) Attach your sample to the case
Let me know if you need further assistance.
How can I paste a screen print. I can show you visually what I am talking about. I didn't set any extra properties. I like the control the way it works until this happens, which I'm thinking is a bug.
Can you please provide us with an isolated sample reproducing the issue?
Have you set Expand Direction?
http://samples.infragistics.com/2010.3/WebFeatureBrowser/contents.aspx?showCode=true&t=WebDataMenu/WebMenuPropertyExplorer.aspx~srcview.aspx?path=~srcview.aspx?path=WebDataMenu/WebMenuPropertyExplorer.src
Is it option in your scenario to use the Scrolling feature of the WebDataMenu?
http://samples.infragistics.com/2010.3/WebFeatureBrowser/contents.aspx?showCode=true&t=WebDataMenu/Scrolling/WebDataMenuScrolling.aspx~srcview.aspx?path=~srcview.aspx?path=WebDataMenu/Scrolling/WebDataMenuScrolling.src
Hope hearing from you.
