I am using a XamDataChart to show a histogram, by binding a list of a custom class like:
class DataItem { public string Label { get; set; } public double Value { get; set;} }
My Xmal looks like this:
<ig:XamDataChart Name="xamDataChart1">
<ig:XamDataChart.Axes>
<ig:NumericYAxis x:Name="yAxis" MaximumValue="18" MinimumValue="0" />
<ig:CategoryXAxis
x:Name="xAxis"
ItemsSource="{Binding Series}"
Label="{}{Label}"
Gap="0"/>
</ig:XamDataChart.Axes>
<ig:XamDataChart.Series>
<ig:ColumnSeries
x:Name="series"
XAxis="{Binding ElementName=xAxis}"
YAxis="{Binding ElementName=yAxis}"
ValueMemberPath="Value">
</ig:ColumnSeries>
</ig:XamDataChart.Series>
</ig:XamDataChart>
What I am trying to do is show a tool tip on each column in the series to show the value of that given datapoint, is there anyway to do this with the tooltip, so far I can't seem to be able to do this.
Hi ,
To set the equivalent ToolTip binding in code behind , you can do the following -
StackPanel sp = new StackPanel(); TextBlock tb1 = new TextBlock(); TextBlock tb2 = new TextBlock(); sp.Children.Add(tb1); sp.Children.Add(tb2); tb1.SetBinding(TextBlock.TextProperty, new Binding("Item.Label")); tb2.SetBinding(TextBlock.TextProperty, new Binding("Item.Value")); xmSeries.ToolTip = sp;
Where "Label" and "Value" are the String and Numeric Columns respectively in the datasource , mapping to the Label and Value .
-Shilpa
And how would you achieve this view code behind..? If the whole chart was created dynamically ...like
e.g:
ColumnSeries xmSeries = new ColumnSeries();
xmSeries.ValueMemberPath = "Value";
xmSeries.XAxis = xmXAxis;
xmSeries.YAxis = xmYAxis;
xmSeries.ItemsSource = dp;
xmSeries.Brush = new SolidColorBrush(colors[tupleCount % colors.Count()]);
xmSeries.Title = seriesName;
ToolTipControl control = new ToolTipControl();
control.DisplayTooltip(seriesName, tooltipValue);
xmSeries.ToolTip = control;
seriescol.Add(xmSeries);
The above codes foes not work as the series has only one datapoint....
You can display the value of the datapoint on each of the respective Column by setting the ToolTip property of the ColumnSeries like ,
<ig:ColumnSeries x:Name="series" ItemsSource="{Binding Series}" XAxis="{Binding ElementName=xAxis}" YAxis="{Binding ElementName=yAxis}" ValueMemberPath="Value"> <ig:ColumnSeries.ToolTip> <StackPanel > <TextBlock Text="{Binding Item.Label}" /> <TextBlock Text="{Binding Item.Value}" /> </StackPanel> </ig:ColumnSeries.ToolTip></ig:ColumnSeries>
Hope this helps ..
