How can I change the navigation pane toggle button text to say something other than "Navigation Pane"?
Thank You!
-Sam
Yes, that's helps a ton!
Thanks!
There is a StringSettings property off the XamOutlookBar object which has NavigationPaneMinimizedText property. You should be able to achieve what you want by setting this property.
HTH,
