733
Importing excel workbook values issue
This is infragistics 10.3.  Is there a way to get the formatted value of a cell from a workbook that's been read in from a file?  The issue is that the second column contains dates.  But to excel, a date is a number with a format string applied.  So when I try to read the value I get a number like 40653 instead of "4/20/11".  Neither .value or .tostring() return the formatted value.  Did I miss something?
  • 44743
    Getting the value based on the format string is currently not supported. You can submit a feature request for this. If you detect the format string is a date string, you can pass the cell value into the static ExcelCalcValue.ExcelDateToDateTime method and then format that DateTime value approapriately based on the format.
