Hi All,
I am getting below issues while using V10.3 version with IE9. Could any one give a suggestion what exactly the problem ?
Hello ushealthgroup,
I have created support ticket: CAS-65559-G8DZV4. Please attach sample with steps to reproduce. We will investigate and will inform you how to resolve this.
I dont think this issue is resolved I have the latest version and the same issue is still present. what can we do to get this resolved?
Hi bigger,
this is a known issue and it is fixed in the latest service releases. v10.3.20103.1013 was released before IE9, that's why it is possible to have issues with it under IE9. You will not be able to download newer versions until you upgrade. If you want you can attach sample reproducing the issue and I will test it with the latest service releas. Or you can open Trial support ticket.
Best regards
Hi Hristo,
I'm having the same issue with UltraWebGrid. My subscription already expired. I wanted to check if I upgrade to the newest version it will resolve my problem (and a little comment about your "probably" - I thought Infragistics is a technical company and when I hear something like "it will _probably_ resolve your issue..." it really makes me sick).
I've just installed the trial version. Upgarded my project to work with it and the problem is still there! The trial version is v10.3.20103.1013. I don't have access to newer version. I don't want to spend a lot of money on new version without the guarantee it will work. How do I get the newer version to check if the problem is resolved?
Best regards.
Hi yashwanth258,
v10.3.20103.1013 was released before IE9. Install latest service release, probably it will resolve this issue.
