I am using V10.3 control of XamPivotGrid. To this grid i want to bind custom data, i.e. based on users selection of cube, dimension, measures. I don't want to use XamPivotDataSelector control.
I have my own custom service layer. For returning the data based on MDX fired i am using GridData class which was built by you guys for Custom Data Provider Project. Following is the post.
http://blogs.infragistics.com/blogs/engineering/archive/2010/10/26/building-a-custom-data-provider-for-xampivotgrid-in-silverlight-using-wcf-and-adomd-net.aspx
now i want to bind this GridData class to my pivotgrid. I tried but didn't succeed. Can you please let me know how to achieve it.
Thanks,Sachin.
I have attached a sample which works odd times. Can you help to fix this issue attached?
Hi Sachin,
Are you using the sample provided in the blog post as a guide? They are binding the xamPivotGrid to a static resource defined in the xaml. You would need to update the connection string.
I’m not sure that I understand your reference to the GridData class. What data source are you using?
Is the bind not loading the pivotgrid or are you having trouble defining the row, columns, and measures for your pivotgrid?
Please give me more details or perhaps the best approach would be for you to provide me with your own sample.
