1130
xamslider
I have a xamgrid which has a TemplateColumn containing a Datavisualization chart.  There are multiple rows which render, each having a seperate chart(line chart).
I have one slider beneath my xamgrid which has ticks in it for all of the dates which have a datapoint represented on any of the graphs.  When you select a point on the slider, it will take that date and display detailed info on all the plotted points in all the graphs for that date.
My goal is to have a  vertical line which falls across all the graphs, so when the slider is moved, the line moves across the graphs along with the slider thumb.
Is there a way to style the slider's thumb so it is a long vertical line which extends across the objects(graphs) above it?  Would it be possible to style the thumb with a "z" index?
Thanks in advance for any suggestions.
Dave Krecker
