could anybody please give me an example on how to drag&drop between two XamDataTrees on the same page? I've set up the drag&drop manager on both trees like this, but none of the events are fired when I drag or drop an element from the other tree over this tree (Drag&Drop within each tree works fine):<DataTemplate ><StackPanel Orientation ="Horizontal" ><Image Source="{Binding Data.Image}" VerticalAlignment="Center"/><TextBlock Margin="3,0,0,0" Text="{Binding Data.Label}" VerticalAlignment="Center"></TextBlock><ig:DragDropManager.DragSource><ig:DragSource IsDraggable="{Binding Data.IsNotRoot}" DragChannels="altTree" DragEnter="DragSource_DragEnter" DragStart="DragSource_DragStart_Alt" DragOver="DragSource_DragOver_Alt" Drop="DragSource_Drop_Alt" DataObject="{Binding Data}"/></ig:DragDropManager.DragSource><ig:DragDropManager.DropTarget><ig:DropTarget IsDropTarget="True" DropChannels="altTree, mainTree" /> </ig:DragDropManager.DropTarget></StackPanel></DataTemplate>
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I created a sample project for you with the functionality you want.
