We are running 2010.3 - 2120 version of infragistics. We tried to enable CDN on our website but found that the grids with Browser="Xml" do not display at all. If we remove Browser="Xml" it loads correctly. We use Browser="Xml" to load data 50 rows at a time for virtual scrolling.To enable CDN we added the following to the web.config with no change to any of the other files:Under the configuration/configSections we added<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>Under the configuration section added<infragistics.web styleSetName="Default" enableCdn="True"/>Thanks in advance.
Hello Singal,
I would like to inform you that this issue has been resolved now.
Thank you for this report. I have created a support ticket CAS-65175-CB0VPC in your behalf in order to investigate this further.
