I've been digging through the samples and documentation and not seen any of this yet, so figured I'd ask. Is it possible to have several (small) reports be combined at run time into a single larger report?
This is definitely a scenario we've identified, and is something that we plan to add in a future release. It has not currently been scheduled, so I can't really give you any more specific time frame, but its great to have the scenario specifics.
Devin
Is this something that might be available at some later date?
I'll give you the situation we have. We have various report components (usually four different kinds) that can occur with one to many frequency for each one, and need the same standard header. Within each component the individual elements are identical but between components there is little to no similarity. That is the situation in which this question comes from; because traditionally we have used multiple small reports that were then amalgamated into a larger report.
Hi Collin
This will not be possible in our V1 release.
Andres
