I'm looking for a control similar to the ToggleButtonTool available in WPF version of the xamRibbon. I've tried to inherit a control from RibbonTool in my project, but it contains some internal properties that make this impossible. Now I mimic the behaviour of the toggle button using a single radio button in a separate group.
Do you have plans to implement ToggleButtonTool for Silverlight? If no, can you suggest any solution for this case?
Thanks for the reply. I'll stick with the RadioButtonTool as a toggle button.
We currently have a SegmentedStateMenuTool that allows the user to click on the button portion of the MenuTool. The issue with using this though is that it is a MenuTool and as such the button portion will be disabled if the Menu has no children. I do not know if in your case it would make sense to have menu childred associated with the toggle, but that is currently what we have.
I do not know of any current plans to implement the ToggleButtonTool, but I will see what I can find out.
Rich
