If you're using bound columns in the XamGrid and you are using indexers as your keys, is there someway to specify to you which indexer you want to use?
We've got a data type that has two indexers on it. One a type-safe class that's nice for confirming that you're not passing garbage into the class as a key and one that takes a string and works well for binding expressions.
The problem is that everytime we add a column to the grid with an indexed expression, under the hood an exception's getting thrown. It's getting trapped internally to Infragistics code and it's eventually resolving properly, but I'm getting eaten alive by QA because WinDbg is showing the errors. The AmbiguousMatchException gets thrown in this stack ...
042f1d8 6a35f8e4 System.RuntimeType.GetPropertyImpl(System.String, System.Reflection.BindingFlags, System.Reflection.Binder, System.Type, System.Type[], System.Reflection.ParameterModifier[])
0042f200 6a0f161e System.Type.GetProperty(System.String)
0042f20c 036fa558 Infragistics.DataManagerBase.ResolveIndexerPropertyInfo(System.String, Int32, Int32, System.Type, System.Collections.Generic.List`1<System.Object>)
0042f264 036fa259 Infragistics.DataManagerBase.BuildPropertyExpressionFromPropertyName(System.String, System.Linq.Expressions.ParameterExpression)
0042f29c 036f9cb4 Infragistics.Controls.Grids.ColumnLayout.OnColumnAdded(Infragistics.Controls.Grids.ColumnBase)
0042f2d8 036f99d2 Infragistics.Controls.Grids.ColumnBaseCollection.AddItem(Int32, Infragistics.Controls.Grids.ColumnBase)
0042f2f0 037b8ef1 Infragistics.Collections.CollectionBase`1[[System.__Canon, mscorlib]].Add(System.__Canon)
The general way to resolve this error is to provide a type to the GetProperty() method to indicate what you're looking for. Do you support anything other than int and string? Is there anyway to designate to you which indexer is being targeted?
This issue has been resolved in service release: build 2233 for 10.3 and build 2029 for 11.1.
Valerie
