How to produce issueAdd XamDataTree and subscribe to event SelectedNodesCollectionChanged and event is firing on mouse over.
I found this forum entry in WPF which looks to raise the same issue:http://community.infragistics.com/forums/t/48667.aspx
Additional Details:On initial load when nothing is selected mouse over doesn't raise the event but after a node is clicked the event is raised on mouse over from then on.
Hello Sandeep,
I have created a sample project for you following your scenario and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
Hi
I am currently using 11.2.20112.2125 which is newer version than the one you mentioned. I am also facing the same issue. Also i am not running with debug break point.
Sandeep
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I can say that this issue has been fixed in the latest service release of 11.2 (11.2.20112.2068), so I suggest you download it by logging to our web site and going to My IG \My Keys and Downloads.
