Does XamMap control overwrite the default exception? For example: When we play the storyboard that target to the element that doesn't exist, we used to get the exception like "Cannot resolve TargetName {NAME}".. but after we add the XamlMap control, all exceptions that we are getting is this exception ""Element is already the child of another element."".. Why?
Here is the step to reproduce the issue.
1. Create new Silverlight 4 project in VS 2010 and add the following assemblies.
InfragisticsSL4.v10.3InfragisticsSL4.DataVisualization.v10.3InfragisticsSL4.Controls.Maps.XamMap.v10.3
3. Add this storyboard in UserControl.Resources of MainPage.xaml.
<Storyboard x:Name="showDotImageStoryboard"> <DoubleAnimationUsingKeyFrames x:Name="opacityKeyFrame" Storyboard.TargetProperty="(UIElement.Opacity)" Storyboard.TargetName="dotImageControl"> <EasingDoubleKeyFrame KeyTime="0" Value="0"/> <EasingDoubleKeyFrame KeyTime="0:0:0.3" Value="0"/> <EasingDoubleKeyFrame KeyTime="0:0:0.7" Value="1"/> </DoubleAnimationUsingKeyFrames></Storyboard>
4. Run the project. Observe: You will see this exception "Cannot resolve TargetName dotImageControl." which is correct.
5. Add XamlMap control in Grid "LayoutRoot"
6. Run the project again and check the exception
The expected exception : Cannot resolve TargetName dotImageControl.
The actual exception : "Element is already the child of another element."
Feel free to let me know if you need more information.
Hi Michael,
I see this is a pressing matter for you, so I have contacted our DS team and they are going to reslove this for you at earliest.
Ivan Kotev
Can you tell me how to use XamMap's Office 2010 Theme.? We already have our own style template for the map... How to use Office 2010 Theme without affecting our styles? Thanks.
Please let us know when we can get the fix.. it's kinda blockage for us since it's making our life harder to trace the issue..
The issue has been fixed and should be available it in the next service release. In the meantime as a workaround try using the XamMap's Office 2010 Theme.
Thanks for reporting the issue.
I have been able to reproduce the issue.
I am looking into it and I will post back here my findings.
