In my previous post, http://community.infragistics.com/forums/t/53636.aspx, I finally got multi-row tab levels being added programatically. Now I face an issue where the first level of the tabs is "mushed" together with the second level - there is no spacing between them.
I have tried the following and none of them seemed to make a difference:
How can I create a bit of white space or separation between the first level of tabs and the second?
See the attached screenshot - there are 2 levels of tabs, with a total of 5 tabs. As you can see there is no definition between one level and the next - I'd like some sort of white line to appear between the two levels.
Strange - I seem to have fixed my problem. I tried the 4 things I tried before and found that #2 really did work, so not sure what happened and why it didn't show up before. Anyway, at least it's working now!
