35
Problem in Paging with outlookGroupby
I have used a Grid (UltraWebGrid) In that i m using the paging & GroupBy option both. But when i made a Group on any column the paging is disable. That is Page numbers are not displayed after grouping.
please suggest any solution.
  • 485
    Check with following -
    mobjCServerGrid.DisplayLayout.EnableInternalRowsManagement = true ;
  • 5
     Had the same issue myself.Solved it by the using the ultragrid event "GroupColumn" to max out the page size.
    UltraWebGrid1.DisplayLayout.Pager.PageSize = 10000;
    UltraWebGrid1.DataBind();
    Regards
