Using TargetTypeName="Node" uses the ItemTemplate and outputs the ff
There is nothing in the tree that would do that. You would either have to prefilter your data collection to remove those elements, or you might be able to retemplate the NodeControl and associate the .HasChildren of the node with the Visibiltiy of the control through a converter.
Is there a way to hide the automatically generated header node if there are no children?
Thanks for the sample Valerie, this does serve the purpose of assigning different looks. The previous ones (Composite and Composite2) did not include any converters.
The only limitation of the recursive NodeLayout is that it requires all root nodes to be of type Folder, meaning it cannot handle the case where a File can appear in the root level. This can be done using an earlier suggestion but this will introduce unnecessary levels in between (ex. Folders). Please close the related case as it seems we have reached the best possible resolution.
You could create different looks for the files and the folders using a converter to assign the Content to the Content Presenter in the Item Template. I believe I showed you this in a prior sample. I am attaching a sample using option 1 with the converter to see if this resolves your issue.
Valerie
Thank you Valerie, the 1st option is the answer I'm looking for.
Actually I've already tried that previously but I couldn't find a way to use a different template for the leaf nodes. Used the same strategy for xamGrid and couldn't find a way to use different templates either.
XAML test code is as follows:
<UserControl.Resources>
<DataTemplate x:Key="TreeFolderTemplate">
<TextBlock Text="{Binding Data.Name}"/>
</DataTemplate>
<DataTemplate x:Key="GridFolderTemplate">
<TextBlock Text="{Binding Name}"/>
</UserControl.Resources>
<StackPanel Orientation="Horizontal">
<ig:XamGrid x:Name="grid"
ItemsSource="{Binding Folders}"
AutoGenerateColumns="False">
<ig:XamGrid.ColumnLayouts>
<ig:ColumnLayout Key="Children" TargetTypeName="Folder">
<ig:ColumnLayout.Columns>
<ig:TemplateColumn Key="Text" HeaderText="Name"
ItemTemplate="{StaticResource GridFolderTemplate}" />
</ig:ColumnLayout.Columns>
</ig:ColumnLayout>
</ig:XamGrid.ColumnLayouts>
</ig:XamGrid>
<ig:XamDataTree x:Name="dataTree"
DisplayMemberPath="Name">
<ig:XamDataTree.GlobalNodeLayouts>
<ig:NodeLayout Key="Children"
DisplayMemberPath="Text"
ItemTemplate="{StaticResource TreeFolderTemplate}" />
</ig:XamDataTree.GlobalNodeLayouts>
</ig:XamDataTree>
</StackPanel>
Any suggestion on how to apply a different ItemTemplate to the leaf nodes (File type) using this recursive layout?
Also, I noticed that I cannot apply the same ItemTemplate to xamDataTree and xamGrid because the Binding is inconsistent (Data.Name vs. Name). Am I just missing something here or is this really how they work?
