Hi, we are using the timeline control to show data for example for the "past 3 years", e.g 06/13/2008 - 06/13/2011. But on the axis we only want to show tickmarks for every full year.
I am using:
DateAxis.UnitType = DateTimeUnitType.Years; DateAxis.Unit = 1;
AutioRange is set to "false" and we explicitly set "Minimum" and "Maximum" for the axis.
And we also format the tickmark label to only show the year.
The problem is that the tickmarks are placed on 06/13/2008, 06/13/2009, 06/13/2010 etc. since the control seems to automatically start the tickmarks at the beginning of the date range, but it only shows "2008", "2009" "2010" at the tickmark due to our label formatting and the UnitType setting.
I want the axis date range to be 06/13/2008 - 06/13/2011, but I want tickmarks on 01/01/2009, 01/01/2010, 01/01/2011 etc.
Is this possible?
Thank you.
I have created feature request for your issue. If it is picked up for development you will be notified with an email.Your reference number for this feature request is FR13291.
If you require any further assistance please do not hesitate to ask.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
Unfortunately, currently we are not supporting this. The tick marks start from the begging of the range. You can submit a feature request about this at:
http://devcenter.infragistics.com/protected/requestfeature.aspx
