795
binding column to complex collection
I posted this to the WCF Data Service forum, but thought I would try here too since I'm using xamgrid.
I'm using silverlight to display objects retrieved from a WCF Data Service in a datagrid (i.e. the datagrid is being bound to a DataServiceCollection<GponOnt>).  My GponOnt object has a navigation property called GponOntLocations that contains all the locations the GponOnt serves.  I can of course bind directly to GponOntLocations and use a value converter to convert the collection of GponOntLocation objects to a string for display but in order to use all the filtering/grouping provided natively by the grid, it would be better if I bound the column to a simple "string" type instead of the collection.  Given that, I thought I would just use partial classes on the client side like:
  public partial class SrvStreetLocation
    public override string ToString()
      string addr = this.HouseNumber.Trim();
      if (AdrStreet != null)
        addr = (addr + " " + this.AdrStreet.PreDirectional).Trim();
        addr = (addr + " " + this.AdrStreet.Street).Trim();
        addr = (addr + " " + this.AdrStreet.StreetSuffix).Trim();
      addr = (addr + " " + this.Apartment).Trim();
      return addr;
  public partial class GponOnt
    public string Locations
      get
        if (GponOntLocations != null)
          return string.Join(",", (from l in GponOntLocations select l.SrvLocation.SrvStreetLocation.ToString()).ToArray());
        else
          return "";
This works great, but when I go to perform CRUD operations on the GponOnt objects and post them back to the server with SaveChanges, I of course get an error saying "property name 'Locations' is not valid.  I thought, simple , I'll just add a [NonMapped] or [NotSerialized] attribute to the above code but alas, I find the Silverlight version of the library doesn't support those.  Anyone know of an easy solution to make this synthetic property I've created not be serialized or an equivalent workaround?
