Ist it Posiple to set the DefinitionUri of the Reportviewer by Code. I would like to show one XAML Page with a Dropdown or so, in wich the user can select the Reporttype, and then bind it to the viewer,
Yes it is possible. You can bind the DefinitionUri property or set its value directly in the code. Take a look at the samples installed together with the CTP for an example on how to do it by code.
Leo
