I am sure there is a simple way to do this, but having tried a few ways with no success I thought I better post the question.
I have a map with multiple layers (world, state, county etc.). Each layer is bound to the same data source currently and displaying data as a heat map. Depending on the the query run by the user the source could hold data associated with either countries, states, counties. This data is being pulled dynamically from a SSAS data source and to change the query the user is selecting levels of a geographic heierarchy.
The issue I have is that when the data source changes, the heat map of a particular layer is not being cleared down and remains the colour it was before even though there is no data associated with the elements. I have tried binding to the DataSource property of the map layer and using property changed events to update the UI. I have tried setting the DataSource property manually and calling DataBind(). I have also tried calling RenderWindow() after updating the source, each having no effect.
Any help would be appreciated.
Chris
Thank you, the workaround, although not ideal, has resolved the problem.
Hi Chris,
Please, take a look at the following post: http://forums.infragistics.com/forums/p/53321/276279.aspx#276279.
Hope that helps,Milana Zhileva
Have been able to get the desired behaviour, but I am sure there must be a better way than this:
protected override void ResetElements() { map.Layers[CountriesLayer].Elements.ToList().ForEach(ResetElement); map.Layers[StatesLayer].Elements.ToList().ForEach(ResetElement); map.Layers[UsCountiesLayer].Elements.ToList().ForEach(ResetElement); map.Layers[UkCountiesLayer].Elements.ToList().ForEach(ResetElement); }
private static void ResetElement(MapElement element) { if (!string.IsNullOrEmpty(element.Caption)) element.Caption = element.Name; element.Value = double.NaN; } protected override void InitializeData(List<SimpleDataCollection> data) { ResetElements(); MapData = data.Count == 1 ? data[0] : null; UpdateElements(); } private void UpdateElements() { map.Layers[CountriesLayer].Elements.ToList().ForEach(el => UpdateElement(el, true)); map.Layers[StatesLayer].Elements.ToList().ForEach(el => UpdateElement(el, false)); map.Layers[UsCountiesLayer].Elements.ToList().ForEach(el => UpdateElement(el, false)); map.Layers[UkCountiesLayer].Elements.ToList().ForEach(el => UpdateElement(el, false)); } private static void UpdateElement(MapElement element, bool isCountry) { if (isCountry) { // Just show country names where we have values element.Caption = double.IsNaN(element.Value) ? string.Empty : string.Format("{0} ({1})", element.Name, element.Value); } else { // Show name regardless for states/counties element.Caption = double.IsNaN(element.Value) ? element.Name : string.Format("{0} ({1})", element.Name, element.Value); } }
