How can I get all my 25 titles to show on the timeline? As you can see from below screenshot only 3 titles are shown. I need all 25 titles represented by each dot to show. How can I accomplish this?
Here is my code:
<igtl:XamTimeline x:Name="xamTimeline" Width="900" Height="250" Title="Milestone" >
<igtl:XamTimeline.Axis>
<igtl:NumericTimeAxis Minimum="1" Maximum="27" AutoRange="True" ShowLabels="True" Unit="1" />
</igtl:XamTimeline.Axis>
<igtl:XamTimeline.PreviewAxis>
<igtl:PreviewAxis ShowLabels="True" />
</igtl:XamTimeline.PreviewAxis>
</igtl:XamTimeline>
Code behind:
milestoneClubs = DataUtil.MilesotneClubs;
// xamTimeline data binding
NumericTimeSeries series = new NumericTimeSeries();
series.DataSource = milestoneClubs;
// data mapping
series.DataMapping = "Time=ID;Title=Note;Details=Note;";
this.xamTimeline.Series.Add(series);
I don’t see your screenshot but I do see that you have set the Minimum and Maximum property of the NumericTimeAxis which is normally used to define the axis range.
However you also have the AutoRange set to true which would cause the chart to determine the minimum and maximum range.
If you can post your screenshot I’ll try to give you some specific assistance but the chart will display as many of the labels as possible for the available space by default.
By setting the AutoRange to False and adding 5 numericTimeEntry items to the series between 3 and 15 I was able see all of the very simple labels that I was working with.
Depending on the Titles of the numericTimeEntry in your series, more or less space may be necessary to display the labels. You might consider increasing the height of the timeline or possibly re-template the labels style.
