670
Cancel a postback?
Is there a way to selectively cancel a postback depending on the tab using client script? I have tried trapping the before tab changed event and using return true or return false and also oEvent.needPostBack=false; and nothing seems to work.
I need to post back only two of the 10 tabs to ensure a webgrid is properly populated (another odd thing).
  • 65
     Hope my codes is useful to you. It works wellonmy machine.
            function UltraWebTab_Main_BeforeSelectedTabChange(oWebTab, oTab, oEvent)
                switch (oTab.getText())
                    case "Contact Information":
                        oEvent.needPostBack = true;
                        break;
                    case "Feedbacks":
                        break;
                    default:
                        oEvent.needPostBack = false;
                        break;
                        <igtab:ultrawebtab id="UltraWebTab_Main"  runat="server" dummytargeturl=" "
                            height="100%" width="100%">
                            <ClientSideEvents BeforeSelectedTabChange="UltraWebTab_Main_BeforeSelectedTabChange" />
                        </igtab:ultrawebtab>
            protected void UltraWebTab_Main_TabClick(object sender, Infragistics.WebUI.UltraWebTab.WebTabEvent e)
                switch (e.Tab.Text)
                        Populate_ContactInformationTab();
                        break;
                    case "Participants":
                        break;
                    case "Feedbacks":
                        Populate_Feedbacks();
                        break;
  • 670
    Verified Answer
    Never mind. I found an alternative approach that works better.
    I turned off AutoPostBack, and check the AfterSelectedTabChange event.
    If the tab is one with a grid, send an AJAX command to refresh the grid invokeXmlHttpRequest(oGrid.eReqType.Refresh,null,"");
