320
Not able to access silverlight samples
I am trying to access the silverlight samples, Is there an equivalent of feature browser in silverlight where I can view the code & run the sample. I saw the samples(local) but when I run it a window opens up with url that contains only the .exe file.
Thanks, Naveen
  • 8607
    Hello Naveen,
    You can access the silverlight samples online.  You can view the code beneath the sample.  I think that the only prerequisite is to have the Silverlight plugin installed for your browser.
    Silverlight LOB samples
    Silverlight DV samples
    You could also try to open the solution that is installed locally with the samples installer.  There should be a start menu shortcut to the "samples source code", where you'll find the solution file.
    Let me know if you have further questions.
    Elizabeth Albert
    Localization Engineer
