In version 10.3 it was possible to set Markers for Column Series chart using XamDataChart during runtime using codebehind. But,
in V11.1 i am unable to find MarkerTemplate property so that i can set it during runtime from code behind. Has this property been removed from being exposed in codebehind.
Thanks,Sachin.
I am checking if this is still an issue for you.
If you require any further assistance please do not hesitate to ask.
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
Hi Sachin,
I tried to reproduce the issue you are seeing with our 11.1 release build, and was able to get the MarkerTemplate property off of my ColumnSeries object. Could you create a small project reproducing your issue, and attach it here? This would better help me assist you.
Marisa
