795
grouping problem on optional nested properties
When binding to data from a WCF Data Service (aka oData), you often end up wanting to bind to nested properties on sub-objects that have been been "Expanded" into the main object:
<ig:TextColumn Key="SrvItem.SrvService.AccountID" />
The SrvItem object will either be null or a fully populated object with all its sub-objects also populated - the binding mechanism is smart enough to deal with nulls anywhere along the path - but when you go to group by the column, the grid throws an exception - presumably because that mechanism isn't smart enough to deal with nulls anywhere along the path.  It would be nice if this could be fixed.
