I wish to save preferences of a grid with the tool of persistence 'PersistenceManager'.
The backup does not work when applying two filters on a column that contains 4.
Indeed, during recovery, all filters are applied to this column.
Best regards.
This has been resolved in the following service releases:
Silverlight_10.2.20102.2409, Silverlight_10.3.20103.2246, Silverlight_11.1.20111.2054.
Ok, thanks.
Yoann.
There appears to be an issue saving the setting if the Select All checkbox is unchecked then the items are selected from the filter list. This has been logged with development and I will create a private case to notify you of any changes with this issue.
Valerie
Someone can help me please?
Regards.
Hi!
Valerie, I use the last version of Net Advantage (11.1.20111.1004).
MolallaComm, I already use the same code than you, and I already have FilteringScope="ColumnLayout". My problem persist, thanks for your help.
