i have an issue saving and loading the layout of xamdockmanager.
I create the panes dynamically, always assigning a SerializationId to the pane.
When i load a saved layout, the content size is not applied to the panes.
If i float, resize, dock and save again, the layout is applied.
Similar behavior exists on your sample, i resize the right splitpane, and save the layout as shown
then i select the layout#1 item and load the layout, the screen becomes like below
Also it seems that it does not persist the selected tab on each tabgroup pane.
Michael
Hi Michael,
those two seam like a bugs. I have created bug items for them:
These bug items will be associated to your support case so you could be notified when they are resolved.
Hello konstantin,
do you mean the CAS-67544-ZK7YRS support case or you will create a new one?
no , there is new case opened for this thread already - CAS-68647-WC67PN.
