Hi all,I'd like to use lazy loading in my Silverlight XamDataTree. I've already read this topic :http://blogs.infragistics.com/forums/t/50958.aspxBut it doesn't help me. While clicking on the expansion indicator, I'd like the "ghost" node to disappear and my wanted nodes to be loaded. I think it's like dynamically add nodes in the tree.Here is an example : Normal 0 21 false false false FR X-NONE X-NONE MicrosoftInternetExplorer4
void resultXdt_NodeExpansionChanged(object sender, NodeExpansionChangedEventArgs e)
XamDataTree xdt = sender as XamDataTree;
XamDataTreeNode xdtnode = e.Node;
//XDTNode is the type of all my nodes, DisplayMemberPath is set on "Description" attribute
XDTNode xdtn = xdtnode.Data as XDTNode;
//RelatedTo is a collection of XDTNode children
//Here I remove a ghost XDTNode used to show the expansion indicator
xdtn.RelatedTo.Clear();
//Here I add a testing node in the "RelatedTo" collection
xdtn.RelatedTo.Add(new XDTNode()
Name = "try",
Description = "try",
RelatedTo = new List<XDTNode>()
With this the tree does not update automatically when I expand my first node, I always see my "ghost" node, and I don't see my "try" node.I'd like to use this kind of functionallity to avoid endless loop in my code, because I use this control in a particular way...Does any one have an idea ? Did I miss something ? Do you understand my request ? Thank you all
Hi again,
Here was my mistake :
Using a List<XDTNode> won't allow the tree to see the change. I changed with ObservableCollection<XDTNode> and now it works just fine.
Thank you anyway :)
