550
Parameters Exceptioin
I am getting the following exception when my view first loads.  I have default parameters set for the report and am using IEnumerable ObjectsSource.
Object reference not set to an instance of an object.
at Infragistics.Controls.Reports.XamReportViewer.CheckForReportParameters(Boolean reset)
at Infragistics.Controls.Reports.ViewerStateMachine.Render(Boolean firstRender, IDictionary`2 selectedParameterValues)
at Infragistics.Controls.Reports.ViewerStateMachine.ApplyAutoRender()
at Infragistics.Controls.Reports.ViewerStateMachine.set_IsVisualReady(Boolean value)
at Infragistics.Controls.Reports.XamReportViewer.ReportViewerLoaded(Object sender, RoutedEventArgs e)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
at System.Windows.BroadcastEventHelper.BroadcastEvent(DependencyObject root, RoutedEvent routedEvent)
at System.Windows.BroadcastEventHelper.BroadcastLoadedEvent(Object root)
at MS.Internal.LoadedOrUnloadedOperation.DoWork()
at System.Windows.Media.MediaContext.FireLoadedPendingCallbacks()
at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
 The report renders when the submit button is clicked on the parameters tab.  The parameters are not held when the user takes the focus off of the report viewer to another view.  I cant find a way to bind the parameters to stop this from happening.
Eric Larson
