I used this link :
http://community.infragistics.com/blogs/atanas_dyulgerov/archive/2010/01/27/how-to-set-up-xmla-http-access-for-sql-server-analysis-service-2008-and-access-the-adventure-works-2008-from-an-infragistics-pivotgrid-application.aspx
in order to setup the XMLA HTTP access to SSAS 2008.
After the setup I am able to connect from Excel and SQL Management Studio but not from XamPivotTable using the same connection string.
Is there anything I can do ?
Thank you,
Dimitris
Could you share what the problem was. It may be useful for other people
found the problem, thank u
I did that but nothing changed
Hi
Check your clientpolicy.xml file. the most over the problem are connected with it.
Todor
