270
Can't select another item from the Combo
I put a webcombo in a webpanel control and set the datasource to a .NET SqlDataSource result set on the same page. I don't change anything from the default. All I do is map the appropriate fields for the return value.
When I run the project, I can freely select an item from the dropdown (albiet the font looks totally unprofessional in it's anti-aliased and slightly blurred form). The page posts back and I get the return information from my other code. I then attempt to select another dropdown item. The list drops and then I want to scroll. As soon as I click on either scroll button, or even the slider, the box closes as if I had clicked far away from the control.
According to other messages in this thread, something similar happened in V6 of the control set. I'm having the problem with 7.3
I can't upgrade to the 8.1 version (if it's even fixed in there) due to department policy on my end. I can't downgrade to 7.2 because I'm using a new feature of 7.3 in my project.
I can't provide any code. Actually, in this case, since I'm using a basic instance of the control, recreating the steps should be easy.
  • 185
    I'm in the same situation, but with the 8.1 version.... [:'(]
    With IE works fine, but with FireFox no.
    If I build a traditional ASP.NET 2.0 project works with all browsers, but if I build a project with AJAX extensions enabled, I have the problem with FireFox.
    Any idea?
    Thanks in advance.
